stuvy
worked in bodyshops for over 25 years, only ever had 1 hammer, never stuck yet.
What’s your weapon of choice
I’d like a second hammer for panel beating like this but don’t fancy paying £26 has anyone seen any others cheaper?
It has to have a flat 20mm(approximately) pein
if its just the straight pein part of the hammer you want, just use a woodworking one but polish the faces to suit.
If it's a reasonably decent brand hammer, you can knock the handle off grind or forge it to what ever shape you want, then with a gas torch heat up the face so its getting towards a bright red let it soak back a quarter inch then hold it in the shade when it's dark red drop it in a bucket of water. Once it's cold stick a handle back on it and your off, though like postie jon even though i've got a loads of hammers and access to thousands I do tend to use the same two or three.
Made hammers in odd shapes to get into tight corners but my go to is still the Proto 1427
Tried the carpenters hammer with polished face & peen it just did not feel comfortable in hand
When I say I have access to thousands of hammersthis is just a fraction of our new-old stock
Don't let @The_Yellow_Ardvark loose in your stores!!![]()
My favorite mer, yep I have a favorite! is a W77.
you got a shot of the draw full of naked W77s?
