julianthegypsy
- Cirencester
@jinjahbiscuit , You have been busy!
Yes Julian, but I'm very happy. I'm pretty much made up now, apart from some kind of saw, I'm complete! (You have been busy!
)Had to go to the bigger B&Q today to get some more laminate flooring (they have changed their flooring lines and the stuff I need for the kitchen to match the rest of the house had been sent to the larger store to go on clearance) and picked up these 2 boxes of screws. 1400 pieces per box, one was £25 the other was £20. They should keep me going for a little bit, I was getting low on some sizes.
Had to move some gear..
To make room for this...
Many thanks to Nick for his patience.
No more acquisitions allowed this trip! Er, well I might get hold of some brazing kit.
Nice one! Turn it around so it's across the timber wall and the headstock is away from the corner. It's a change-gear lathe and fiddling with the gears will get old very quick where you have it situated. Either that or put a low bench in the corner for the drill press to stand on, that'll give you half a chance at least.
Thanks for the advice Pete, nothing is screwed down yet, so things can be moved around reasonably easily. I'm presently building a bench for the drill.
There's also an old 1920's lathe in there that I might sell to give me a little more space.
ouchAn tooth abscess, swollen face. Hole in the gum line, large dentist bill.
Mine's set up with the headstock end towards the garage door for long stuff through spindle, tailstock end lined up with mill table so I can put a tailstock on it and get a few feet more between centres too.
Dave H. (the other one)
a different one An tooth abscess, swollen face. Hole in the gum line, large dentist bill.
Also found out found the blow function works great at blowing the undercoat out of our Malamute dog, which should hopefully reduce the hair dropped in the house.
Did you get a thump from the burger and chips man?An tooth abscess, swollen face. Hole in the gum line, large dentist bill.
Milwaukee M18 wet and dry vacuum
Already cleaned down the garage and cleared the dust off the rowing machine yesterday. Used this morning attached to the circular saw and much less cleaning up. Also found out found the blow function works great at blowing the undercoat out of our Malamute dog, which should hopefully reduce the hair dropped in the house.
Tell me about it, that's why I went for these, few sizes I don't often need but for that price I couldn't turn them down, as you say the box is excellent. I've got several different sized Stanley boxes with various sizes in so might be able to re-purpose some of them now.You can get those in screwfix too (same company as b&q). They are good value considering you are getting a really good box with them. The turbogold screws are brilliant but you'll get a scare when you want to refill the box - they are expensive!
