DAPPH
as dyslexik as I'm daft
I was given 2 of those trampolines & I have yet to find a use for the tubing. It is quite thin walled & when you grind off the galv there isn't a lot of steel left. I tried to weld a bit of it with the mig & it doesn't weld nicely. I might be able to use some of the push fit joints for something but it will probably all end up going back to China via the scrap yard!![]()
The legs are good enough to stack on in the other to make a 12 foot or longer tall tube . Push a welded eybolt through the top end leg and add a 6 to 1 Haltrak type pulley set . Add a mtr long 30 x 30 angle iron with a welded on hoop in the middle & Hey Presto you have a fantastic aid for lifting in & out fence panels in H section posts all by yourself . Making up 400 x 400 foot plate with a peg on it for the tube to slip into at the bottom is also helpful to stop things sliding away . I used ratchet straps to secure the panels to the bar & old carabiners to fit them to the pulley & bar . Managed 22 panels most of which had to have a tad planed off with an electric plane over two days ( 10 hrs total time ) including treating the planed edges with preservative . took the old panels out with a sabre saw .
To get the height the easiest & safest way I found was start off with the top section and keep adding from below then put it on the foot plate at the centre of the panels base .
good boy and kept nine of them .
