Tangledfeet
Think outside, no box required.
- Top of a hill above St Andrews, Fife
Plus I found this in a box.
Havent seen it for 10+ years.
A Wolfcraft thing.
Didn't your village get electricity last year?![]()
Why not light the gas lights or a candle
The Lincoln procedure handbook of arc welding, far more info than I will ever need but it was 20 quid
13th edition, whatever that makes itwhat year i have the 1932 leather bound job
What it is going in?
It’s going to be a ground runner for taking to shows, will be mounted on a trailerWhat it is going in?
That sounds fairly typical for ADSL2. If you have fibre to the cabinet you should be able to get considerably better speeds, but you may need to upgrade your broadband account and may need a different (VDSL/VDSL2) modem.Just ran a test and it came back with this Ping: 39ms D/load 20.65Mbps Upload 1.11Mbps
Before, d/load was between 3 & 4Mbps so a big improvement. U/load was [iirc] 0.35Mbps so improved but still great?![]()
Abut 18 months ago BT dropped in a new cabinet 200 mtrs from here & dragged fibre into it then it went quiet for a few months , along came the change over team & the black hand gang 7 a new cable route was put in to connect both cabinets & connect up the copper to the optical converter. Nothing much happened for several month then slowly but surely the connection speeds have increased now it is amazing .That sounds fairly typical for ADSL2. If you have fibre to the cabinet you should be able to get considerably better speeds, but you may need to upgrade your broadband account and may need a different (VDSL/VDSL2) modem.
New Manager to me.
"Why do you have to be on site for three hours, for the yearly visit?'
I replied.
" The regulation states: The yearly visit is to be of a duration of 180 minutes of battery power."
His reply:
"Well can't we just say we have done it?'
My reply.(short version).
No.
i might be teaching you to suck eggs, and call me Professor Paranoid Cynic, but I *strongly* recommend you buy yourself a journal/notebook and start recording *all* of these conversations/snippets with dates/times.
because it IS going to go bad - and you'll be glad you have evidence.
And if I'm wrong: "better to have and not need, than need and not have"
Have done.
All my e mails have a private addresses set to BCC. So I have records.
I have forwarded his recent ones to the account manager and HR.
