- SW Scotland
Do you still have power or has the main plug fuse blown? I can't run my CUT40 any higher than 32A on the dial when connected to 13A. Even then it's limited to shorter runs, anything more just blows the fuse.
If the power's still there then are the trigger leads working? Ie take the torch button lead off and test the continuity. Obviously whilst disconnected from the power
Next stage would be to check inside whilst it's off and look for a blown internal fuse.
.00
It has a machine torch on it for cnc which I will swop out for their hand held kit so there will be one in the ads section after I get it!
