thanks , looks like I can go up to 8250kg max and have no vin . but about half that weight would be enough for meUnless you have B+E or “Grandfather rights”, you’re limited to;
Car or van, up to 3500kgs, plus a trailer of 750kg MAM.
Car or van, plus trailer over 750kg MAM, as long as the total train weight isn’t over 3500kg.
If you passed before 1st August 1997, your total train weight can be 8250kg.
MAM - Maximum Authorised Mass
EDIT:
Car weights should be on a sticker on the door jam, or vin plate.
https://www.towbarexpress.co.uk/maximum-towing-weight/
https://www.gov.uk/towing-with-car
Technically, if it isn’t plated for towing, you shouldn’t.thanks , looks like I can go up to 8250kg max and have no vin . but about half that weight would be enough for me
I never noticed that before - my 2007 Alfa has a figure there 100kg greater than the chassis plate
And as DVLA can't fill in the model name as they have no EC number to do so for my Dodge Challenger, there's nothing in that box . . .or on the US VIN sticker . . .
If you take the car to a (council ?) weigh bridge then for a small fee they will confirm weight.its a Beauford kit and has no weights in log book , originally registered and inspected with the chassis and engine nos then issued with a number plate and mot , it was supplyed with a tow bar, registered before sva came in , I have been towing about half ton now and again , built about 1992
I have a full driving licence and hgv 3
DO NOT use real weight, unladen weight, googled weight, you get the picture. Only use weights from the vehicles V5c in section F1 or the top number on the weight plate PLUS the biggest number on the trailers weight plate.
EVEN IF BOTH ARE EMPTY. The TOTAL must be 3500kg or less.
You won’t win.you're wrong on that bit... there was a big discussion about it on the forum transit forum, someone there emailed back and forth with VOSA and posted the replies up for everyone to see
car and trailer both need to be under their individual max weight
car weight plus trailer weight need to be under the cars train weight
and unless you have the license for it (probably not) the car needs to be heavier than the trailer
