This pedal has a 5k pot.The pedal number is 10-4016.
They use different pedals and control sockets. I imagine they work on the same resistance value for the potentiometer but you’d need the pin-out info for both machines to do the conversion. What’s the best price you’ve seen on the Parweld pedal?
It does but it’s only an additional pot to limit the max current. It doesn’t need to be thereThe Parweld pedal has a pot. on the side which is used for setting the maximum current.
About£140+vat
This scc thermal arc is new in box at £86.
I'll keep an eye out for a proper one now I'm doing a bit more alloy.
By the time you buy it, get the correct plug, then find out you get max current potential on the pedal at all times then the genuine Parweld pedal will seem like a bargain.
Ill give you the £86 for the Thermal Ark one if you dont want it ( plus any postage)About£140+vat
