angellonewolf
- bristol england
this one(2 of actualy) but an older one nicd battery version
i have cheaked and they say i need 12v and 150mA charger now i got a 12 volt 1000mA charger and pluged it in and it does charge it but get hot and smells not very strong but if you get your nose near it you can detect a electronic smell thats not good
now from memory when using a differant power supply for most items as long as you got the right voltage and more amps than needed it should be all right
eg 12 volt 1000mA you can use a 12v 2.1A charger as the unit your powering will only take what it needs out of the amps so just the 1000mA but as this is for charging not powering does this make a differance eg if i use the 12v 1000mA charger will it try to charge the battery fast hence the over current and hence the smell as its to much for the charging circut ?
