chris pruteanu
- ROMANIA
Looks very good, love the progress you make!
it takes a lot of the key design points from the Roubo bench such as flat vertical faces for clamping and sliding deadman and holes in the top for hold-downs, dogs and clamps. I like the idea of putting power and air through the legs, I can't do that with a concrete floor so I'm going to drop power, air and extraction from the ceiling, I already do this with extraction on my assembly table, which would be useful if it wasn't covered in junk.
You can probably use the 19mm hold down in a 20mm hole...
Just checked accugr up, 200 mm cast iron control handwheel is about 27 quid plus vat and carriage, choice of drilling square holes etc
Chris
How about this Andy? I'm sure you've a corner you could slip it intohttp://www.lathes.co.uk/advertphoto/181029-dominion/
From memory it is about 8" across and it was an eBay special. Must be4 years since I bought it.How big was the rejected handwheel and where did you get it from?
