Screwdriver
That makes sense, so you are still getting the heat that would normally escape up the flue. Your sketchup diagram looks spot on, I think I will try a garage version like that.
The rocket stove or rocket heater/burner is a fascinating and very clever piece of technology. The science behind it is equally fascinating which is how I got into them. Having said that, there are some fundamental design parameters you really need to get in the right ballpark; size of the firebox vs. size of flue and size of the primary air inlet. They need to be within a certain range of proportions. Remember you're building an air pump and air is heavier than you think at this altitude.
For example, take an average size room, say 6m x 4m, 3m high. Ok, that's a smallish room or a biggish shed. How heavy do you think the air is in that size space?
Wrong! If you gathered up all the air in your room, filled a balloon and weighed it, it would be over 70Kg!
IKR. Hard to believe but one cubic metre of air weighs 1.2Kg. Great little anecdote for the kids or free rounds down the pub...
But that weight or pressure can work to your advantage in two ways. Firstly hot air is a lot less dense and therefore lighter so you don't need that much of it in your insulated flue to start shoving cold dense air out of the way. Secondly, once you start shoving it, it develops a momentum in whatever direction you coerce it, especially if that volume of air is contained in a flue. Hence the need to get your volumes and apertures the right sort of size and relative proportion.
But i'm not very technical at this sort of stuff.
I cant hold my hand on the exchanger but compared to the firebox which is 10x hotter, if that gives you an idea.
... you have me worried now
