Some stick welds, 70 amps 2.5mm rod, 3 and 4mm thickness on the square tubing. I think this is th ebest stick welding joint I have made so far. I started out at 100 amps but that was too high, blew holes in the thinner wall tube when I tried doing an up hill pass, kept adjusting dowwards, maybe could have gone to 75A. They turned out nice though, and the welding machine is really nice to stick weld with, I can jam the electrode in real good and it won't give a damn, real hard to make the arc go out.
This I welded earlier at 100 amps, two passes, one root pass, just a straight stringer then a sort of weave.
I've done so little welding lately it feels like starting from zero again but towards the end it was going real well and I felt my skills improve.
Looks good!
Recently I have been using MMA for most things. I could have used mig for them but MMA just felt a lot better. A mig weld can hide a lot of problems but a MMA weld takes no prisoners, if it looks bad is usually is bad & a decent MMA weld gives more satisfaction.
Got her tumble drier working, needs a new belt and felt bearing. Another job for the new year
