Shox Dr
Chief Engineer to Carlos Fandango
- East Yorkshire
Thought I’d start a project to give me full 3ph access in my workshop. The intention is to use a 7.5kw Invertor, connected to 5x 240 3ph outlets, via either relays or rotor switch.
Using 1 (of7) to control each outlet.
1 Tool grinder 750w motor
2 TS Light vertical 1.5hp
3 M300 3hp
4 TS ELT major 1.5hp
5 spare
Each machine will have its own pendant for Start/Stop fwd/rev, jog, and E Stop and a Pot for variable speed if necessary. All fitted into an enclosure (I’ll probably build)
This is the Invertor I want to use.
Can anyone foresee a problem using that VFD, before I hit the button
3 M300 3hp
5 spare
The Button was pressed
. I've got a 3 phase socket on the output of my VFD (2Kw I think) and a hook with three plugs hanging off it for my lathe, mill and drill (1.5, 1 and 0.3KW respectively). I thought about a big rotary switch or a load of relays but decided a socket and plugs was cheapest and most foolproof.
