mrsbruce
- Livingston, Scotland
I had finished the ceiling of hubby’s hut, but after a LOT of rain last night, I found a couple of leaks. I dug out a tin of that leak stop roof paint stuff, and got some gloop over the screws/spaces/overlaps on one side if the hut ok.
While doing that, I came to the conclusion that the rain was perhaps being blown in under the roof capping. I considered spraying some expanding foam from the inside, and took a ceiling panel down, but lots of aluminium tape, insulation, etc, in the way. I tried running foam from outside, but being a shortstop, getting to the apex of the roof is ‘not easy’. I could use an extension tube on the can, or maybe create a heath robinson extension stick and trigger pull for the foam can.
Or, and this may be a silly idea, but would using self stick roof felt be an idea, and just cover the whole roof. I know the gaps are there to allow air circulation, stop moisture build up, etc, but that isn't much cop if all the water is being blown in.
Any thoughts on how to deal with this? Usually I am fairly creative with this sort of thing, but just not sure of the best (cheap/easy) approach.
