alloy and stainless, isnt that a no no due to galvanic corrosion?
https://www.albanycountyfasteners.com/blog/2017/09/15/stainless-steel-and-aluminum/
No, or, yes, depending on how you do it! Dipping the bolt in zinc chromate paste will enable the bolt to still be removed- in a marine environment- years later. Do the same with monel rivets. If the fastening schedule for the bolts/washers etc. allows it then by all means add insulating washers as well.
Without such treatment the combination is deadly even in the relatively short term.
