indy4x
- Pontypool, South Wales. UK
Cheers, I may well take you up on that if my current enquiries draw a blankIf you are stuck i could make one for you
I would have loaned you one16 x 2.5 isn't too bad to single-point. I have to make a 1/2" x 10tpi LH nut which is possible but not easy at all so I've taken the wimp option of ordering a rather expensive left hand ACME tap.
Is it any good for the post holer grab jaws?I have acquired a mini gas cylinder, I have no idea why I acquired it, or what to do with it, but it was all shiny so I couldn't leave it.
I think the boxford is 7/16 or 3/8Ah, I would have taken you up on that but I didn't think to ask. Is that a Boxford cross slide screw size?
When we did the grey top coat we got to a point where we did get stuck in the corner but we had a ladder at the back and did indeed have a cuppa and snack sent up by the neighbour.Looks like @Olderisbetter has epoxied himself into a corner of the roof, and is having his meals sent up there on a rope ?
Some of my old planes have had names on the blade that can only be seen when you take the appart.View attachment 156085 View attachment 156086 View attachment 156087 View attachment 156088 not the best of pics.
I picked this solid brass plane up today.
No makers name or marks I see.
Any ideas on the maker??
Axeminster Tools used to make them..
Look in the plane, cap iron or stamped in the adjusting screw.
Dates may be found on the inside of the body
Also look for any government marks. A lot of brass tools and non ferrous tools were made for the following.
Working in Munitions factories, brass no sparks and then nothing goes boom. Plus that mean nothing goes away.
Also on minesweepers, the idea on early hips was to reduce as much ferrous materials on board to reduce the magnetic signature. This led to De Gaussing of the ships with power cables, a good side shot.
Plus in the early Radar ground stations there was a rush to make non magnetic tools to tune the sets, as ferrous tools would interfere with setting up..
@daleyd you may recall that special tools for tuning 1006 sets in the Grad..
