eLuSiVeMiTe
Have a few sets of these great for the lathe and mill.Every time I use my lathe then have to clean it I often thought that some type of cover would be great. My lathe is a myford ml7 & it a pig to clean because its so small and you can't get in with a dustpan & brush.If the swarf is dry I can use a hoover but today I was drilling holes & using lots of oil so the swarf was a sticky mess!
I'll have a look at my lathe & try to design something similar to your cover.![]()
https://www.amazon.co.uk/Dustpan-Cl...coding=UTF8&psc=1&refRID=PYX8TPSQ2KAS14RTK0CS
Easy to hang near each machine too.
. I may need to mill a
, and painters arrived to do the exterior woodwork on the house. Base will be the same size with 7" uprights [old bits of 6mm tube at the corners], to stop the bottles tilting. Lick of paint and job should be a good 'un.
