Thats the stuff that takes time to learn and implement. If you make assumptions they are not always correct. For example in octoprint there is a box that says motors off...which I thought would disable steppers....but it doesnt on mine..lolThere's an extraneous G92 in there but it's because I didn't used to have extruder motor hold on and springy stuff like nylon would push the gear back, you don't need both.
Wait till you start printing and see how long it actually takes...lolFinally got my new printer, took about 30 mins to assemble, 5 mins to set up, 5 mins to start my first print and about another 10 minutes to now think I should have purchased a bigger one!
Not sure how the slicer works out the nozzle path, it seems a little odd and inefficient at times?
IMHO having just started you are better to get a smaller machine while learning for various reasons not least errors will be exaggerated and temptation to build bigger models straight away will use more time and filament especially if you get errors.
PLUS if you need a larger one you have the small one for any smaller jobs while the larger one is tied up for days.
I have just been offered a Geeetech A30 for under £350 so i am selling my last two vinyl cutters and shifting the rest of my Tshirts to fund the purchase ...
I just had one guy ask me for 5 shirts with
Its back...
HAMMER TIME
out of the blue. I had them advertised on facebook for a fiver and not had one sale in 3 months....strange just when i need the money i get asked...now to find my heat press out.
How did you find out about the 10% off.There is another 10% off Ebay today which may work out cheaper?
I am now trying a 0.8mm nozzle to see if it works or not, should reduce the print time but not sure if it will stick to the bed, may try a 0.6mm after
I thought that would be the case...thanks for confirming mate.Everywhere, otherwise the arms won't be supported.
on the older version you click on the model then click "lie flat"How do you make sure the base of a model is actually flat on the base using cura?
The screw had actually come from my hot end. Has anyone else had /seen/heard of this happening before.?
And then there's foundry work: 3d print the pattern, cast it in aluminium![]()
Speak now or forever hold your piece
).You need borscilate glass as it's heat resistant.Oh dear what have you guys done? Pandora's box is now open.
I spent the last few hours reading the thread hoping I'd find some useful names & to get and insight into 3D printing. As you can see I've got to Hoods post # 236. Then the rot's set in, I signed up to " Onshape " & started the tutorial.
I've suddenly discovered the world I've been seeking for about 15 years. When I got a supposedly quality garden designing programme for extortionate price of about £ 35, but my computer memory & speed was not up to handling it so it got dropped as it wouldn't run on my next new bigger better spec computer.
Same thing happened with a 3D self design house build programme . I had all the details for a four double bedroomed bungalow with external workshop , got it down to the type of front door & it all crashed time & time again, all due to computer related technical problems and stone aged internet speeds. BT's recent uplift to a digital cabinet 200 mtrs away has settled down and teething problems have been ironed out … things connection are taking off.
Santa in Fishnets sent an elf back at 21.00 hrs., bearing good news for what appears to be a decent printer FLSUN 3D Printer plus Prusia i3 diy kit, dual nozzle, ". It's soon to be ordered &put on his sledge ", unless of course the guys on here start screaming don't do it Dave . (Speak now or forever hold your piece
I'm now going to read the rest of this thread to see what else I can glean besides that, " Using filaments with the variable appearance & lumpy measurements of a pearl bead necklace ain't going to be conclusive to getting an even thickness to the layer of plastic being deposited from the printing head.
One question , putting the glass on the table /base, Is shop window plate glass at say 8 to 10 mm mm thick or so OK ?
Dave
