give me half and hour and I will post what its printed...its not finished yet but my grandson is sitting watching it. lol it might make more sense seeing what I have done to it..Question is what do you mean? If you open Gcode in cura it will usually draw it on screen with the supports layer by layer
Or do you need to create supports to make something work?
Took a quick pic which might show it.give me half and hour and I will post what its printed...its not finished yet but my grandson is sitting watching it. lol it might make more sense seeing what I have done to it..![]()
STL never have the basic supports, ok almost never, some folk design in supports to snap out, like the adjustable spanners for example. Curas basic setting is "from buildplate" that's ground up, "everywhere" would put supports on the dinos back if his tail curved over.Note all the support.
I added that as the stl file came with none......but i guess the tail would fall off...…….. if i printed without support?
phew...lol yeah I found out cura sticks supports all over the place if you use defaults...lol I thought I had defeated it..by using touching build plate...but I think it ignored me...STL never have the basic supports, ok almost never, some folk design in supports to snap out, like the adjustable spanners for example. Curas basic setting is "from buildplate" that's ground up, "everywhere" would put supports on the dinos back if his tail curved over.
There are also difference in PLA and ABS "build angles" and bridging...….
how...lolI still use Onshape for free.
Yes, it is cloud based and works in a browser but it seems to work ok.
I use Solidworks at my job 8 hours a day and 5 days a week and Onshape is very similar.
In some respects it is better because they have combined some commands.
For instance the extrude command can either cut or add or intersect
I use it and Fusion 360.
I use Simplify3D for 3D printing.
It is not cheap but it works very well
Andy
now that looks good...no one will ever want to print my designs if I ever make any. lol
https://www.thingiverse.com/thing:1666671
this is what I am trying to design. mine would be primitive this would be better but according to the comments it does not print correctly and as after slicing it seems like it will take 5 hours to print. so the comments might be correct.
how do I check what it will print out like?
