sardine
- Buckinghamshire
25 ft long bolt cutters ?I have a tower scaffold... 50 50?
Lol.
You climb. Im scared of heights
Lol.
Is it an ASI paratrooper?
Should really say im scared of ladders.I have to ask. Why do you have a scaffold tower then?
On about those, that's another area where H&S screws things up. Mobile towers aren't exactly the most obliging things for handballing large, heavy items up, but if you stick to the PASMA regs, tasks like that become nigh on impossible, because then the guard rails get in the way. So, if you go on a site which requires one to be PASMA qualified, for some tasks, you can't actually do your work without risk of losing your cert. Rock & a hard place.
There's a huge old railway works near me that is due for demolition, there are probably a hundred of the big 24 ." ones in there, but the roof is 20 foot high and falling in, so no chance of salvage. Place is a death trap.
I only know because i have one up the loft and yes its the .177 repeater with the tube on the top.Older, ..that is the name that elgamo used when importing to UK, they were elgamo68's known as ASI paratrooper, well spotted.
There was an odd repeating one too, a break barrel repeater !
Someone wanted to undo the screw at the rear ( of the compression tube) on mine so instead of an' easy out' they took a torch to the screw/end cap and melted away the ally. The frame is ally, the working parts only are steel.
After a strip down I had to ensure the ''tube is fastened down at the rear (pic)
I've also tapped a long bolt underneath, into the tube , the rifle was given to me with a plastic tie holding the rear by the owner/ rifle destroyer !View attachment 151595
Not today but recently acquired this parts washer, decent size leak and mess free table top cabinet with fan and light. Draws the degreaser up from the reservoir a bit like a sand blaster, a valve to adjust the fluid, fine mesh washable strainer for the returning fluid, decent light inside and an extractor fan .
You can swap the degreaser in the resevoir for water for the final blast off.
Its a gem
Too noisy.How about a small battery operated disc cutter on a pole, with a couple of friends holding an old blanket to catch the lamp ? Not kidding.
I think they are hung on thin chain.
A small air or hydraulic operated cutter on a joined length of 32 mm plastic plumbing pipe, with a landing net attached is my best guess.
I
A long pruning lopper.There's a huge old railway works near me that is due for demolition, there are probably a hundred of the big 24 ." ones in there, but the roof is 20 foot high and falling in, so no chance of salvage. Place is a death trap.
Ideally, I'd like to source a sticker for the fuel tank as per the auction pic
I do this quite often for many different projects. I use these people, they'll make custom stickers out of vinyl or a different material in most sizes with multiple designs per run.
