angellonewolf
- bristol england
hi there if u be doing car panels its no good as it only goes down to 40 which it will burn more than give good weldi had just seen this, 5 years and German (so it says) quality. but then noticed it has 16amp. https://www.ebay.co.uk/itm/Welder-S...266120&hash=item23a0991912:g:gigAAOSwzrlbWYhE
ah ok thanks. yes i would be doing car panels. what do i need to look for? thankshi there if u be doing car panels its no good as it only goes down to 40 which it will burn more than give good weld
Hi. looking for my Mig first welder, been reading up and doing a little research, have very little funds though.
I dont have a shed or workshop so would be outside work all the time. Bits of work on my camper but want to learn how to do other things. Been told to avoid owt under 140amp.
Just wondered if anyone has upgraded but has a nice decent one going cheapish and same with bits etc. thanks
thanks. was going to ask what was a visor to start with.get yourself an automask and some welding gloves
https://www.ebay.co.uk/itm/Auto-Dar...Powered/291083830247?var=&hash=item43c5f2c3e7
wire i think i have some of that but will check wire is for gas mig only i dont have any gasless wire
a regulator for a large bottle of gas but its older depends if you want to use it or not
if you are wanting it post in the for sale section of the site also states to others that your wanting it
the post is here
https://www.mig-welding.co.uk/forum/threads/sip-migmate-150.84528/
depence wat u want to spend and if u be doing it far long periods clarkes 135te are realy good , i used in the past cebora pocket mig which was brilliant, now 160 gys and r-tech i use to use before retirementah ok thanks. yes i would be doing car panels. what do i need to look for? thanks
ta Gaz. Be some time before i can afford to go gas... it did seem so easy with gas though. i looked on ebay and saw some small bottles, rather than big ones like yours. In a couple of weeks hopefully grab the helmet, gloves and couple of other bits.. I need to find where to get metal etc in Sheffield thats cheap. You said look on the forums but i dont A from B on what to buy or what to avoid... good or bad etc. its all totally new to me.mask as posted above
gloves
https://www.ebay.co.uk/itm/Premium-...248316?hash=item3f8733a4bc:g:1acAAOSwOrxZwtdO
we was on about mig wire 0.8
https://www.ebay.co.uk/itm/Precisio...514870&hash=item2a193e864e:g:6PgAAOSwQItUEIXc
https://www.ebay.co.uk/itm/Mild-Steel-Mig-Welding-Wire-ALL-SIZES-0-7kg-5kg-15kg-0-6-0-8-1-0-1-2/231872762439?hash=item35fcb19247:m:mx9MqsxNeejJ33pEdzXiE0w&var=531106445361
just remember the wire is as important as the user poor wire can give poor welds
the adapter i said it needed as ive never had it just picked this one to show you which one to get
https://www.ebay.co.uk/itm/5Kg-Mig-...398623&hash=item43fd175889:g:3XAAAOSwNnRYh2S8
nearly forgot i was using a boc bottle y argoshield light
https://www.mig-welding.co.uk/forum/threads/boc-volkszone-offer.79928/
or you can post on the forums as your shefield based tehy maybe other alternatives you can use instead of boc
just post on this thread
https://www.mig-welding.co.uk/forum/forums/shielding-gas-and-regulators.27/
happy practice welding though dont forget need help post a pic on forums and many of us will aid you in your welding learning on here as ive only given you the basics even with 2hrs here but digging everything out id say around 15 mins practice time with a gas only system running
