God mode restorations
- uk colchester
I use these. And a set of small pipe cleaning wire brushes for bolt holes.What method have you used for stripping/cleaning.
I have blasting equipment but it's a faff setting it up and messy. Those wheels do a good job.What method have you used for stripping/cleaning.
They certainly wasn't shy on using materials that's for sure.Looks like it was designed to withstand a direct nuclear strike.![]()
The motor had no adjustment .just bolted down. I will mount an adjustable plate for the new motor.Is that how the belt was tensioned? Those slots?
Arh....Yes it's got a few dings. Nothing I can't sort out on the Mellor latheThe shaft looks a bit scratched, if only you knew someone with a lathe, you could make a new one.![]()
This has been my point all along . You need a lathe to fix the other lathe. And when that's down you nerd another lathe to fix the other ones. That's what I tell myself.The shaft looks a bit scratched, if only you knew someone with a lathe, you could make a new one.![]()
Got the other shaft out today. About two hours of graft getting that b1tch out. View attachment 149660
That one was. It was proper stuck in. All good now thoe.Some can be fun, can't they.![]()
