wyn
- Cardiff
Seen a few of these on youtube and will be needing to do some annealing in the future, so thought i would make one.
It's mostly dictated by what materials i already have in the shed..............3mm sheet, 16mm silver steel, 16mm ID oilite bushes, 3" aluminium round bar.
Started with some 3mm sheet.
Drilled a few holes and turned some round bits to hold the oilite bushes.
Guessed a bit and drilled the holes at 90mm centres.
Welded the bits in
The oilite bushes are a little loose but will probably be ok.
Turned some aluminium rollers and fixed to the shaft with grub screws.
The top one has a cut out to pick up one case.
The bottom one is knurled and i've also cut grooves for o-rings.
A bit of a hopper out of more 3mm.
A guide out of more 3mm
A "flap" out of 3mm stuck to a 10mm rod.
The top roller will be powered and the bottom roller connected to it with a round belt.
The top roller picks up a case from the hopper....Drops it onto the bottom roller which is rotating.
A blow torch is positioned to heat the end of the case. I'll need a smaller torch.
The flap will be timed to the top roller to drop the annealed case just before the next one drops.
These aluminium bits will be the drive pulleys.
The rod controling the flap will be operated by a cam on the top drive pulley.
A 12v dc motor and g/bx plus a speed control thingy turned up this afternoon so i can fit that soon and see if it all works.
Welded the bits in
