maybe not its a gel mat batteryAny screw sadly will corrode in the sulphuric acid after a while
cut it open and crimp or solder perhaps
still gotta be worth a look to cure my curiosity
drill down the terminal with an 8mm drill untill you get a good reading, in a copper 28mm end stop melt some solder ready, a little flux down the hole , warm the terminal with hot air gun as hot as poss, stick a soldering iron down the hole and remove then pour pour the melted solder down the hole, I have repaired many termials by making an aluminium former and reforming them by doing exactly that. especially commercial batteries when the terminal has become loose and blasted the lug away at startup.
exactly so it has disconnected under the terminal so you need to reconnect it you could go to 10mm drill if the terminal is ok.thats an interesting approach the terminal is in perfect condition just not making proper contact with why lays below
when they make traction batteries this is how they do itor this https://www.youtube.com/watch?v=aWD3wOKZvgU
dont think you will hit copper it will just be lead I think, obviously keep the battery tilted so the water /acid is not cooling it when trying to heat it .
