Sitting here tapping the lift lever withUse a tiny drop of brake cleaner on the dial stem to free it up. You might have to do it every time you want to use it if it's been stood a while.
I've got a couple of Mercers that are a little sticky, I'll give that a try.Use a tiny drop of brake cleaner on the dial stem to free it up. You might have to do it every time you want to use it if it's been stood a while.
Looks a bit more presentable now.
View attachment 141997 View attachment 141998
And its party trick and the reason I took a punt on it.
View attachment 141999 View attachment 142000 View attachment 142001
Need to see if I can mount my main dial easily.
That whole section of wall is gonna be clad In 18mm ply.Need to whitewash that wall, you’re quickly building a little engineering works!
Today I acquired
A new parting tool/holder.
Unfortunately other items not here until Monday View attachment 142042
I have two Colchester students. Am some other stuff.What were those other machines you said you had lying around the country? At least one more Colchester student
.... and £5 for some flowers for Mrs TYA.
But tell the truth, you knicked them out someones garden on your way home
Yes it's 4mm. I ordered a big batch of tooling. Different sizes but only couple bits turned up today.Is that a 4mm insert, Spencer? I suspect that'll be heavy going for your lathe on anything other than ali. I use a 2mm and 3mm and I'm running a 1.5hp motor.
You old softy youBut tell the truth, you knicked them out someones garden on your way home
Could do with a 16 amp female and 2 males if there's any spare.A few good sayings.
Don't ask. Don't get.
One mans rubbish is another's mans treasure.
Were there is muck, there is brass.
I ask a friend of a friend if he had a spare 240V 16A plug and socket.
He got back to me today, with a box,
So we went to the pub for a thank you dirty pint.
Just the one.
Then one more.
This is the initial sort out, not bad.
All destined for the skip.
I will sort out what I need.
The rest?
Any one see anything they want or need?
A few good sayings.
Just the one.
Then one more.
The rest?
