Sparkey
Bouncing along!
- France
I like George
Hey! we're in a free world!
Whatever tickles your fancy, mate!
I like George
To be honest part P, is a real pain in the backside. The idea was it stops the stupid from being stupid. But it also stops those of us that are not so daft from making electrical alterations in a workshop or garage. Where extra sockets might be required.
It then leaves you with the choice of getting a qualified electrician to do the work, or effectively braking the law and doing it yourself.
, I could of and should of done the job myself and shoved the regs.......part p is one of those wonderful "looks good on paper" type government ideas.....pricibley is maybe a good idea, in practice its just a pain in the preverbal....
Most of our houses are fitted with 13 amp cable, I thought. On a ring main I guess it's doubled-up, effectively. But I still thought a socket could take a 13A appliance even, on a spur. So I thought 30A cable would be good enough for any appliance up to 30amps.
In fact it is now such a minefield that I don't get involved at all, except for maintainance in my own house.
There is no such thing as 13amp or 30amp cable. Cable size is determined by the permissible volt drop at maximum required current over the intended length. If you do not understand this you should not be dabbling, regardless of any regulations no matter how petty they may seem and I'm not a sparks.W/A
As already discussed due to building regulations you will be breaking the law if you carry out this "amendment". You are not authorised to make such an amendment without prior consultation and certification from a qualified electrician and approval from your local planning department. This is on the basis of Health & Safety.
10mtr of 6mm extension cable dont you mean George? As far as i am aware there are no rules covering extension leads, so you are safe. as you had the socket fitted to part P
http://www.diynot.com/pages/el/el004.php
here they rate 4mm cable at 25amps, the longer the cable the more voltage drop. trouble is with welders they try to make voltage drop up by drawing more amps. 6mm cable recommend. 2.5mm cable will burn. 4mm will work but i would always place save and not put a few pence over safety. George if you buy from B&Q you will be paying more than if you got it from an electrical wholesaler like TLC
