powderblast
- Hull, UK
Hi all i got a load of off cut steel from a scrapper mate of mine and i have made a press with what was there.
i am trying to figure out the best size bottle jack to use, im thinking of getting a 50ton one of ebay for £47.00 because it comes with a thick solid base plate but im not sure if it could just tear the press apart specifically the holes its legs are 90x90 box 6mm wall, 25mm solid pins.
i still have to build a safety cage for the front and get some solid steel for the ram.
i have reinforced the c channel what you press on and also the c channel on the top i have welded plates in the top and also a thick plate were the jack will be pressing.
the weakest point will be the holes? will they hold upto a 50ton jack which with it been an ebay jobby may not actually be as powerful as a 50ton.
i have kept enough room so if it does start to wear the holes i can weld so 10mm thick washers onto every hole this will make it 16mm thick
