Arclikeharrypotter
- Northampton
That was run at 125 dcep. Sounds a little low on juice but I could really see it burning in. That was v up
This.Not sure what these are made of but I should first of all warm it up a fair bit to help with cold cracking
This.
That should of absolutely being heated up to 100°c and held to soak for an hour. It’s obviously a high carbon steel to break like it did. My first thought was cast iron but your grinding sparks confirmed probably a cast steel. Still should of been heated though.
Also I don’t wanna come accross like a HnS **** but welding in an area like that is just asking for trouble. That bench was a total tip and fully loaded with combustible materials. I know you don’t do loads of welding but oily, greasy materials, rags, packaging etc will soon see your pride possessions up in flames if you make a habit of it. You want a nice clear bench if your going to weld and grind.
Yeah they looked quite yellow/orange and plenty of them so I’d say almost certainly a steel and the fact it’s a brittle break would suggest a cast possibly high carbon. Some research would probably confirm. Based on this limited observation in the video I’d say you’ve hit it with a good consumable 7016.Interesting observation re: sparks. I'll have a look myself.
Cold water 10mins. Keep it clean, try not to break the skin. Burns are the worst for getting infected once the skin has brokenOh and while we're at it, there must be some expert opinions here, based on experience: what's the best way to treat a minor burn like this? Other than not setting fire to yourself in the first place. Richard has covered that...
That's it for today though. I was trying to level up the jaws because they're off. Probably took some effort to break the thing in the first place and I had assumed they'd match if I was careful to reposition the jaw where it had been.
It looked like you'd left a large gap between the rear of the insert and the jaw. That's likely why it's off kilter, as it'll be facing downwards.
Anyway, for the record, even a small wound like this has the capacity to go bad or be a pain in the **** for weeks so I hit it with everything I've got. That includes a decent St. Johns first aid kit.
Sterile wipe (it had started weeping).
Sterile Burnshield pad, for which I just ordered up some replacements.
Simple dressing (actually used an eye patch bandage/pad which was the best fit).
Feels right this morning, dressing still looks good. I'll open it up and re dress it this evening. Sounds like overkill but burns are a law unto themselves and can go horribly wrong if you don't treat them seriously.
I'm selling some stuff and meeting up with my overseas buyer later this morning. Then the workshop tidy begins...
This is good advice.Once it is scabbed over, use E45 cream on it.
That’s a nice clad repair.
It’s cleaned up well.
Doesn’t matter if it’s not as tough as the original. You’ve built it up with weld so once you’ve banged a few dents in it you weld it again.
