Parm
Respect The Sound System
- Towcester
I was going to use it on my Oxford: 100a/50v or 75a/80v
So, it should be?
I’ve got a similar if not the same welder as well as some sort of HF Tig add on unit
So, it should be?
If it's Hobson's choice then take it.Yes, but I’m suffering from ‘gift horse’ syndrome.![]()
+1 to thisif looking on the bay of thives (ebay) look for a uk based seller you have more comeback if they are in the uk
You need a gas cooled tig torch wp17 with dinse to rectus 20ka, A gys plug which tom can sort you out with easy as pie. Should get a torch sorted for that cheap enough.Just (hopefully) picked up a gys168 off the bay.(thanks again for headsup - you know who you are!)
Doesn't appear to be cables with it, but not too much over budget.
No it’s a work return.Is a "work return" an earth lead?
Lol.No it’s a work return.
The earth lead is in the mains incoming cable
Edit Yes it’s what you would call an earth lead. Proper term is work return. It’s not really an earth
The word ground works for either.No it’s a work return.
Stick it in MMA and Strike up which will tell you the welding side of it’s good.This arrived this morning:
No leads, but it powers on, and the amps adjust. So far, so good.
It's *mint*.It’s very clean
Quite pricey sets those when new.
I'm nipping over to a mate of mine.Stick it in MMA and Strike up which will tell you the welding side of it’s good.
Stick it in tig and find out which two pins control the switch. @Tom Orrow L will know.
Short them out and listen for a click and a buz
If it does all that it’s probably fair to say it’s live and kicking.
TIG 168Stick it in MMA and Strike up which will tell you the welding side of it’s good.
