The SN is to a newer specification than the SM, it's up to you to decide if you want to use them.
In 50 years in working in the motor/plant trades, I've never known the workshop to have several different grades of engine oil for various models of engine. Usually there's a barrel or bulk oil tank that every engine get filled from, I've also never known an engine blow up because of the oil grade, lack of, no oil, or lack of servicing, yes, but not the grade of engine oil.
I've known vehicle owners to supply their own choice of oil for a service, generally because the workshop buys
It would be incorrect to say the right is a better oil
But not to say it is to a newer specification, I've not read anywhere saying it is better oil.
More than likey because the oil is replaced with the current spec. The vehicles been serviced will also be current. Therefore not requiring [or not understood] older vehicles may require a different rating.
Since the mid 80’s they have been reducing the amount of ZDDP in oil, not sure what is now was as high as 1100ppm.
It's a mine field. I'm fed up of having part used new oil in the garage.
I also have a load of semi synthetic 5 w30
Shox, I fully understand what you are saying, but with modern day oils regarding the spec's, I believe they are more for environmental protection than the actual lubrication qualities of the oil.
Not that I'm saying we should disregard the environmental problems but I do wonder about the different lubrication qualities of the various oil spec's?
In my book, the oil is for lubrication not the environment.
Disposal of waste oil is something else.
Quiet. These 0w oils are good for cold starts and mpg, but no good for engine life. I drove to Poland late last yr. It was interesting to see bearly any big Audi A8 howling past, I wonder if that has anything to do with these low viscosity oils, killing high mileage vehicles.
any oils better than no oilOver the years machining/material spec/tolerences have improved allowing longevity/reliability of the vehicles engine. Tighter tolerances and improved oils have also allowed for oils with less viscosity to aid mileage/reliability.
The days are long gone (thankfully) of rebuilding a BMC engine every 40,000/50,000 mile or a Ford engine at 70,000/75,000 miles and throw into the mix a decoke every 10,000/15,000 miles.....
But too you youngsters out there, that's how things were years ago.
Oil was 20/50W for a reason because machining tolerances and materials used in engines years ago were crap.
Today most car engines will see 150,000/200,000mile without being opened up for any surgery, let alone major surgery.
Years ago service intervals (oil changes) could be as low as a 1000 miles in some cases, 3000 or 5000 miles was normal, not the 15/20,000+ miles of today and the first "Free Service" where you stilled paid for the "Oil n Filter" was at 500 miles.
Arr....the good old days.....![]()
