That’s what I thought as wellBatteries of differing capacity can be mixed and, provided they're the same chemistry, state of health, and at the same temperature, then they will all charge to roughly the same fraction of their capacity.
Never seen a 200AH? I can buy two 110AH quite cheaply
https://www.ebay.co.uk/itm/12V-110A...144312&hash=item3a8cb03bcb:g:T0MAAOSwt7pXMuqW
I hope you've got a monster battery as the amps you're gonna be trying to pull out of a single 12 volt battery with that kind of load are stupidly high, as an example we had one owner wanting to run his kettle off his battery bank, he was pulling around 240amps from his bank of 1380Ah... our advise was save your batteries and just boil a kettle on the gas hob instead.I’ve fitted a 1300 W inverter (mainly to allow the missus to use her hair dryer on a morning)
You’re absolutely right, the missus only gets about 10mins on low heat setting on her hairdryer but she seems to be happy with the arrgt. Solar cell manages to replenish the battery across the day ready for next morning. Switching to LED lights in the van has made a huge difference. Everything else runs on bottled gas, result the missus is happy ergo no ear bashying so I’m happy.I've fitted plenty of 230Ah and bigger capacity batteries on boats, as far as mixing and matching them our advise is always NOT TO, ideally you want the same capacity, same chemistry, same make, same model, basically the same everything if you want them to last.
There is an old saying that is very true... Most batteries don't die a natural death, most batteries are murdered !
RonA
exactly .. as stated on another post re boats I designed a air powered water pump for central heating because a battery pump would kill batteries in a short order.around 240amps from his bank of 1380Ah... our advise was save your batteries and just boil a kettle on the gas hob instead.
Totally agree Danny same as twin parallel battery set ups in vehicles they never REALLY work unless totally isolated from each other and charged separately and then combined when needed to power something ie starter then disconnected again.personally i hate parralell battery systems i'm a belivere in say one big 200AH 12v battery
That is a generalisation not all do, there is a vast difference between alternator voltages and smart charge alternators especially should never be connected to two batteries long term https://www.12voltplanet.co.uk/auxiliary-battery-charging-in-vehicles-with-smart-alternators.htmlalternators put out over 14v,
Whilst these new technologies are great news for the environment they cause problems when it comes to charging a second battery in an after-market application for the following reasons:
An auxiliary battery will not be charging for significant parts of a journey
During the periods when the smart alternator output is below the charging voltage threshold there will be no charging taking place. These periods can be significant when combined over the full length of a journey meaning that any connected auxiliary battery will not receive as much charge as it would if connected to a system with a traditional alternator.
The alternator is shut down by the higher battery voltage, the lagging battery is then not charged enough and will only attain a certain capacity and never go higher it is well known fact this happens. 'Sometimes' you can be lucky and the batteries are matched and receive and equal charge it is a well documented but it very rarely does. the lagging battery then 'pulls down' the good battery when connected together long term.
Why are these technologies a problem for auxiliary battery charging?
leisure batteries will usually suffer when connected parallel with a std battery.
Do whatever you feel like with your expensive batteries but please dont accept that it is as easy as a lot of people maintain, I have done it over the years when younger believing the same ideas and not listening to more experienced autosparks and it allways proved it is not a reliable system, it might work if you are 'lucky' but usually doesnt and any serious autosparks will confirm this fact.
