henry Kadzielski
- Australia Wollongong
Again my two cants worth. My name is Henry, as the fishing industry is "so poor" they discounted my name to 'H' and that I fixed problems or solved them 'H Solutions' was born. Out of a joke here I am. Unofficially started mid 90's, officially started late 1999. Started doing 'the black art' electrical, then gensets, followed by welding, fiberglass, blasting / painting, hydraulics, fabrication in S/S and alli, refrigeration, machining, there is probably others but can't remember. The last thing has been engines and gearboxes, as the need and scope increases then the skills improve. If you are prepared to 'GET OFF YOUR ****' there are lots of things to do. You will find that one job leads into another and things are interrelated. There is always the 'while you are here' senario and it is much easier to get one person to do the entire job than get several tradesmen in in varying times to work in together. Remember it all takes time, with Rome not built in a day, be head down and **** up, be carefull which clients you have and it will come. Best advice I can give is start with one thing and do it properly and well. Best outcome you will be reffered, that is where the recognition will come from
Oh forgot started doing marine electronics in the early 80's, sales and instillations, this also helped
