WorkshopChris
- South East Essex
That only works the first time could get complicated when you end up having to go back and work on a different customers boat.Or some have said they can always say that i am friend or relation doing the work,
The thing to watch with supplying materials is it can soon eat into your day running around picking up parts.
When you are starting out you will charge less than the established operators as you need to get recognition in your field. It is important to note what is fair price for the job and you must be very cautious not to be massively undercharging. If all goes well you will get away with it but if there is something wrong (and most times it may not be due to you) you will need to return and correct. Some customers will try to scam you for everything, be cautious. Another hidden problem is some customers are very willing for you to do all their work, and clarify their position as (they can't get anyone), it may be they are very bad payers and no one will do anything for them. Check you clients out carefully before you start. The biggest problem I had was what to charge, even though I did it on (hourly rate) what rate do you charge. General rule of thumb. Whatever a employee gets doing what you do gets you double it. If a general service man get $25/hr, you would charge $50/hr. This then covers you of phone, insurances, 'holiday pay'. When and only when you get to specialize and gain very good recognition then you can command a higher rate. All you customers will say it 's too expensive, but if they keep coming back it is just talk. Working 14hr day you will not last long, be mindfull, that you need time out as well.
