Jlg
- Cumbria
And if you use a dremol and carfuly cut the crimped bit on the new torch you can save the hose tailSo next problem...
Im trying to replace the hose from the regulator to the machine. What fittings/clamps should I be using? The original hose had a compression clamp thingy to the machine. Can this be replaced for something better like a quick disconnect?
This is the hose connection on the back of the machine.
I'm also trying to replace the torch with one I got from Richard. It has a different fitting for the gas line. Should I keep the quick disconnect or change to something else? And is a jubilee clip good enough to secure the hose?
This is the original quick disconnect fitting.
The one on the new torch. Sorry crap pic but its threaded.
I'm in town for a week in early March, I might be able to pop down one evening depending on tube stations etc.
