Something's not right with that, you've got to do a turn before it engages. There shouldn't be that space on the front bit of the screw. Looks like it's been repainted, chances are it's not had the taper pin replaced to tension the screw again, it's an easy job and you can use a roll pin if the original is lost.
I've taken apart a number 2 before, it's fiddly dismantling them fully. There's another taper pin at the back of the base, knock this out first and the nut is dovetailed into the casting, you can use the screw (once unwound fully) to tap the dovetail out carefully if it is seized in place.
Once upon a time it would have traded as a junk shop, which is what it is; the prices in bygone retro vintage antique shops are bigger than those in junk shops.The shop I sold them do, is one of those shop who claims to be a:
Antique shop.
Vintage shop.
Retro shop.
Bygone shop.
We all know the type.
Was it made by big3 industriesA triangle minx arc welder.
View attachment 128373 View attachment 128374 View attachment 128375
150a single phase air cooled.
Thought it was oil cooled - seller clueless.
Bought unseen (but "working") for a tenner.
Apparently (according to the plate) it will weld 0.9mm/20swg sheet minimum and 9mm plate maximum.
Cool drill cant beat old cast iron ridgidity i would love a herbert multi spindleView attachment 128568 Found on the local tip. Kerry drill 3/4" capacity 2mt spindle. The table was missing so I made one with box section, Its very accurate. The belt cover is the later square one With the use of back gear and inverter I can reduce speed to whatever I want. The motor is 900revs View attachment 128567 [/ATTACH] View attachment 128569
Eazy ex pan
Not at home, so couldn't tell you beyond what is on pics.Was it made by big3 industries
Think it was gkn lincolnNot at home, so couldn't tell you beyond what is on pics.
Says "triangle ltd" on it.
I have no idea.Think it was gkn lincoln
