The smaller of the 3 in there is in my house. Got it for a fiver. There are 2 larger ones there still.
Some can. But most are designed for paraffin.Are you guys using these brass blow lamps? Can they be used with petrol?
Hey there fella. I get to go through Treorchy during the summer months on the bike when I'm heading out towards Aberdare and Brecon.Just the one from the upper photo was there when I saw it. By the way, greetings from over the hill near Treorchy.![]()
Must not ask for you to buy for me.
MUST NOT ASK
Mrs TYA "Do not ask!"
I am not asking, yet.
View attachment 126933 View attachment 126934
A very heavy duty sack truck fitted with aeroplane wheels.
An old metal tool box.
Most of the contents was the usual mixture of old screws, bolts & stuff you find in any tradesmans tool box.
8 metres of chain.
Stud extractor, allen keys, drill bits, taps, punches, pulley wheels, old screwdrivers & a 4ba nut spinner.
A well built right angle drill adapter, just have to figure out how to attach a chuck.
But there was one item that I spotted in the box, a very expensive item that nobody else must have known what it was worth, otherwise it would have cost me more than the £6 I paid!
Can you guess what it was?
Cheers for the heads up on the torch, the polished one was £15.99 though, not sure if that's the going rate for a large polished one. I only picked it up as I'm probably gonna build a Burner Light a bit like the one below. Not sure yet, depends how nice it is once cleaned up. I may just keep it as is.
My mate has done a few and sold them on line. He reckons if you mix flour/salt/white vinegar and a bit of water you can make a paste which you smother on and leave for 24 hours and it comes up very good.
https://www.ebay.co.uk/i/1627934400...=9045384&device=c&campaignid=856227598&crdt=0
Picked up this Milwaukee grinder quick release nut today. Its nicely made but the diameter of it is too big to use with some flap discs so thats a bit annoying.
This one has this flick up piece to open it and it has 2 holes for a spanner to be used also. My big gripe with it is the large diameter means it cant be used with some brands of flap disc.Yours looks slightly different to the one I had. The type which had used a click lock type mechanism turned by hand. It jammed, and I had a terrible time removing the 9" disk after cutting a bunch of breezeblocks. The type you have looks like a pin spanner can also be used on it, but I only see one hole.
