My shed is feather edge board. Similar to weather board, except the board is tapered in the cross section.
waldershelf
My boards at 6 inches wide, at the top they are 7/8th at the bottom 11/4 inch.
Framining is 4x2 covered in 6 mm ply then a membrane, boards on the outside. Roof 18mm osb then onduline.
T+G unless it's free is a waste of space for outside use in the UK........ Ship-lap is a bit more expesive but it allow's the rain to miss the join and flow to the next board and so on..weather board is the same but what I know as weatherboard was a whole lot rougher finished than ship lap..........my preferance now is PVC Coated metal sheets, plenty of colours...u'll still need insulatuion whatever u use......but the steel is maintainence free and will out last u..thats unless ur 21......hahaha...
money wise if ur careful the metal works out about the same as wood if not a little cheaper........and on the plus side if u build next to a wall fence etc u'll never need to get there again........
good luck ....Frank
sadly a little more expensive than the wooden options.My shed is feather edge board. Similar to weather board, except the board is tapered in the cross section.
Basically its 10 ft wide sectional frames built from 4x2 planed wood, then this has a 6mm marine ply cover.ontop of the ply is battons same spacing as the frame. Over which is a membrane same stuff used on roofs. Then the boards are over that. From the inside you see the frame and ply. The plan was always to insulate with kingspan or similar, then line the inside, but a roundtooit got in the way. As all our wordly goods lived in the shed, while we lived in a caravan and rebuilt the house.
The base is concrete, with the walls standing on an outline of engineering bricks. Between the bricks and the wood is a brick work dampproof layer. The frame is fixed through the bricks into the concrete.
Feather edge and weather board do the same job, except weatherboard tends to be planed and about 1/2 an inch thick. I wanted something a bit more substantial and a more rustic look. If money wasnt an issue Oak would have been nice. What ever you choose make sure its treated befor you build.
If I were to do it again, I think the sections would be built and insulated with ply on the inside, then membrane and boards on the outside. Also polish and seal the concrete base when laid. It looks a lot different now, her in doors car port has a roller door as the chickens liked it too much, its also so full of her farmy stuff, quad and freezers that her truck wont go in. I also painted it battle ship grey supposidly to blend in with the dry stone walls, and the hardcore now has more grass than hardcore showing.
When searching on the web there were so many opinions on what makes the best shed, when a shed, a temporary building becomes a permenant structure, how to insulate etc....in the end you choose what you think suits both your purpose / budget and dive in. I travelled many miles looking at sheds and garages, there is some flimsy rubbish around supplied by some so called reputable outfits.
When adding up the cost of the wood sit down and take deep breaths!
I'm estimating the cost of the timbers will probably be a fair bit more than I initially thought.You can get compressed concrete planks, from cedral or Hardie, not cheap though
It's about £25 per square meter, but non rotting, and in various colours
Sadly that's a little out of my price range.Sounds like quality stuff , not to be confused with the sodden 6" gear I purchased from travis perkins that now measures 5", lost its lap and has curled more than a pringle.
Will take some snaps of it tomorrow.
Bob
I have to say I was a little dissatisfied with the MOT 1 I recently purchased from Travis Perkins.When adding up the cost of the wood sit down and take deep breaths!
