God mode restorations
- uk colchester
Just started a strip down and clean up on my Taylor chuck. What do you guys use for oiling for chuck parts.
Ok thanks. Will go get some.Some moly grease, sparingly else you will sling it everywhere when you use the chuck.
What about way oil.
All done now. It's had a complete strip. Clean and oiled.I assume that chuck is off that lathe you're refurbishing? It runs on bronze bearings doesn't it? If so your lubrication is a total loss system like my Myford.
If that is the case you will always have oil flinging off the chuck as it runs from the bearings, it can be a bit messy. So you will definitely not notice oil coming from the chuck itself! I used chainsaw chain oil on my chuck, applied with a brush & wiped off the excess.
Well. I didn't flood it but I make sure that all the rotating parts get a coating of oil.Making me look slack. Barely seen my garage in a month. Looking very smart boss.
How much oil does a chuck really need? As long as it gets the odd squirt to distribute around the scrolls occasionally.
Curious now.
Curious now.
