This gets very confusing...
Looking around, opinion seems divided between having an enclosed atmosphere and having 'good' ventilation.
I can see advantages and disadvantages to both theories - a well ventilated space doesn't suffer (nearly as much) from mould/damp, but a 'sealed' space doesn't/can't draw in damp air following a heated session (just occupying a space will heat it a bit, then the air cools and contracts and draws in external, damp, air).
I don't see how to have both a well insulated and well ventilated space - you can't insulate a hole...
So, which is best?
So, which is best?
Storage of wet/damp machinery is best stored in a yorkshire boarded type building where fresh air can circulate, everything is more or less ambient temp, so condensation doesn't occur.
Where as work areas that has mainly personal movement is better sealed against atmospheric air circulation; easier to keep openings closed, making sure items are dry before bringing them in, etc.
Don't add heat add extraction. Dry stuff and use anti spatter spray thickly
If I light up my big gas torch my anvil immediately get wet as water makes a b line for it, once the anvil is got hot it goes. Now ask yourself do you want to heat all those machines and tools so they see hot to the touch 24, 7?
Operating in the space (i.e. using it like a workshop) you need heat though.
While using kit in the cold can be done, it's not ideal practice.
So, do you keep the space warm and find other ways to deal with condensation or do you leave everything cold and have numb unresponsive hands while using your lathe?
Push comes to shove, I'll wear gloves to operate machinery and let 'everyone' tell me I'm wrong, but I'd rather be comfy![]()
It's simple enough to use heat that doesn't produce water as a by product. Instant UV bathroom heaters are cheap enough, get the halogen type and the are dimmable, [using a light dimmer] andwired through a stat, worked a treat.
I don't think the lighting dimmers will like the load of a halogen heater going through them......
Goes a long way too.I'll give it a go if I can get hold of it, is that similar to Shell Ensis?
