Sanrex must hold on to that part of the control. Victor bastardised the lorch with there system.Have to agree the plug in and out or reach for pedal every time it needs changing would annoy the hell out of me.
Odd that my old thermal arc isnt like that. Plug in pedal select the on off option and adjust max current from the knob.
Does yours take the 7 pin plug?
Can you have a torch switch and a pedal plugged in at the same time?
Ah yes. Sorry I meant 8 pin. Mine is the same plug.No there is only 1 socket so its one or the other. This is the plg 8 pins
http://www.rapidwelding.com/dynamic/DisplayItem.aspx?c=10-9811
That's awesome. Defo worth going down the ssc route.R-Tech Offer the SCC Pedals as an upgrade.
	I've tried the bigger brother 260 rtec digital thing. Was a very decent unit imo.
The coolers are a bit crap imo. Noisy big num things but they'll serve there purpose I'm sure.
Why doesn't fan on demand make sense with a water cooler.?Aye, Another reason i went for a 210 model was it has Fan on Demand. Which makes no sense now when the cooler is on...
Dead right. Unless your unit is been transported around in the boot of a car or carried about by hand you'll never have a reason to go back to a gas cooled set up.You'll never go back to air cooled once you use water cooled
