Jlg
- Cumbria
@brightspark do you know the best way to get rid of the rust inside of a petrol tank
			+++cillit bang and gravel and a good shake@brightspark do you know the best way to get rid of the rust inside of a petrol tank
No I thought about it but it will be very hard as it's only 4 mm thick and about 15cm longNo chance you could drill/thread both parts insert a piece of small bolt thread and screw them together with some locktite?
@Screwdriver it is a small stub but what it pushes into on the other side of the hole isn'tI was assuming the broken part is a small stub at 90 degrees to the shaft which goes though a hole (almost invisible) in picture 3. Without better pictures of what is actually broken and how it needs to reattach, it's kinda difficult to be precise.
No I have tried there just to bigCould you fit a cheap ebay carb, plenty of them about for pit bikes and quads. Then fix it at your leisure.
A 1969 Honda c50What bike is itf from?
C50eWhat Honda 50 is it, C100 or C50? Might have a C100 carb but I think that is a C50/65/70 carb.
