julianf
- devon, uk
Sub-base, so far as i know, is an interface between soil, and concrete.
As i understand it, soil moves, depending on moisture content. The degree of movement will also be dependant on soil make up - ie different soils perform in different ways.
Right?
Which brings me onto when people say "you need 100mm of subbase" or "150mm" etc. without ever asking about the soil conditions?
This is what im trying to avoid with this introduction! : )
As i understand it, the subbase is an inert layer that does not expand and contract with moisture, but will move, very slightly, to take up the movement of the soil?
Or is it just a cheaper substitution for concrete? Ie it would be better to do the whole job with concrete but just more expensive?
The soil here is stoney. Lot of irregular shards of stone. You cant dig the soil with a spade. With effort you can scrape at the surface, or you can use a pick to hack your way though it.
The concrete that ive taken up around the place (just paths, back yards, etc) has been 2" laid on top of about an inch of pea shingle, on top of soil. Some cracking, but no major movement.
I want to lay an internal floor in an old stable. Just domestic use - no lathes etc. Im proposing 4" of concrete, with mesh, on DPM.
My question -
Im finding it hard to see the point of taking out soil that is so hard that i need a pickaxe to work it.
Im tempted to copy what seems to have worked in the past - a layer of pea shingle (which is, to all intents and purposes, self compacting) and then the DPM (no blind, as not needed with shingle) and then the concrete.
What im looking for is someone to say "yep, that will probably be fine" or "no, you cant do that, because...." (without just quoting me specs for clay soil)
Any takers? : )
Right?
My question -
Any takers? : )
how come . I think not how do they build tower blocks and bridges with it then
