brightspark
- yarm stockton on tees
oi don't call me old no need to get personalThat was one of the------ older members
I must read OP's in full
I must read OP's in full.......................................................................![]()
Has to start from somewhereIt's growing up on the roof, not at ground level.......![]()
none of that goes on round Middlesboro the old bill are there most nites catching scrotes with nicked cars with the helicopter a good offspin is using the infrared camera and noticing heat spots in attics then send the old bill round to nick em
Has to start from somewhere![]()
OUT THE FFF---LIPIN MORTAR JOINT ON THE CHIMNEY !!! is my guessHas to start from somewhere![]()
how is he to get to the leaves ??Round Up in a garden pump pressure sprayer. That should give you a good enough jet to douse the leaves. If not you can always extend the lance with a bit of 10mm poly pipe
The top end of my exention ladder at gutter level is as far a I dare climb. So far I have tried a high powered pump action water gun (from the toy store) filled with sodium chloride weed killer. This failed due to the water jets not reaching the plant.
the price of roundup what a wasteHe can get a 10ft jet from a pump sprayer and Round Up will kill the plant from leaf contact.
I thought his name was Martin --------not LanceIf not you can always extend the lance with a bit of 10mm poly pipe
