Any builders about ?
I want to put a 22x10 sectional garage in the corner of the garden, going for 7ft high, that's the easy bit, i want to keep the garage in the corner close to the boundary but not use the garage as a boundary, the garden to the left side is lower by about a 1ft and the garden behind it is lower by nearly 1.5ft
Ii was going to dig a trench about 6" from the boundary and fill it with concrete to stop the slab causing the ground to give way and cause any grief to the neighbors or a crack in the base.
I have been out tonight to dig a test hole and I'm down 3ft and its only just starting to turn to clay which is going to be a lot of shuttering and concrete, would making the slab 6" or 8" in depth and using steel mesh make the slab strong enough to be self supporting so to speak ?
Answer on a post card, or preferably here as you don't have my address.
Thanks in advance
Thanks in advance
