dazza
- Barcelona
No idea i was going to have a go but i don't know anywhere else to get metal from.What did they cut that window with, their genitalia?
No there is no lip it slides in from the back.Your digital display will cover its rough edges won't it.
Fit a nice seal round it. A pinch/grip trim round it would tidy it right up.No there is no lip it slide in from the back.
I will have to do something cant have that.You need a nice bezel for your display
Thought you ordered some pickling paste. It will corrode again. There are still oxides present.Had a a go at cleaning the tank welds with scotchbrite and bar keepers friend. There is still a bit of black here and there may get hold of a stainless brush to sort them out, rather than using the pickling paste.
View attachment 102085 View attachment 102086 View attachment 102087
Yep i did thought i would give this a try first.Thought you ordered some pickling paste. It will corrode again. There are still oxides present.
Don't see any reason why you can't turn the motor.
Do you have the makers name/model for the motor?
Yes no question.It may have been painted over will have a look tomorrow.
I had to do away with the plastic box for the electrical bits so the power supply and relay will be secured to the sheet at the back. The motor is earthed should i add another where the power enters the case?
You must wash it off after use and scotch brite will sort it out nicely. Don't worry about it as it's designed to be on the metal.Oh and i used the pickling paste today. Made a right mess with that slapped it on the welds went for a vape break it cleaned the welds up but ran down a stained other parts of the metal.
