Chainsaw oil is perfect for oiling the gears, don't forget to oil the spigots before fitting the gears. The excess will drip from the bottom of the cover, I keep an oil spillage mat below mine to soak it up.
I'm not sure about the cream highlights on the cover, I prefer the original red.
Been faffing about trying to get the belt/Tri-Leva setup adjusted and sent off the springs which came on the lathe off to Myford to see if they could supply replacements. They haven't arrived after nearly 2 weeks.......
Jack there has said this sometimes happens and when they speak to the Post Office, the items miraculously appear
No great hardship, but I'd like to know what's amiss before I pull it all to bits. Can I assume it's easy to take the whole spindle apart, I've got it on the bench?
Not sure if I could have helped, my thoughts would've been a missing key or grub screw, didn't know about the press fit gear.
Hoping to move on with this now, as other projects are piling up and the lathe is taking up too much space in the middle of the shed.
However, patience saved the day.
Doubt much progress will be made for a few days as Doc & hospital visits will take up much of the week but I'm pleased that the worst/most difficult stage(s) are sorted.
