Would 25mm square box with 3mm walls be any good for the legs and framework?
works perfectly well for me
good solid bench, holds motorbikes engines, you can weld things to it when you need to, holds a bloody big vice, will take a pounding no problem.Mine's bolted to the walls and floor - got some 50mm square plates cut when I got the top cut (2mm mild sheet) welded them to the legs and bolted through.
Much more bench than that seems overkill to me. Lathe bench is made the same, takes a 9" SouthBend OK.
more painful than I thought it was going to be.
