Parm
Respect The Sound System
- Towcester
In my previous shed I regularly ran a propane forge. The main issue when starting to use the forge was working out how much carbon monoxide it would produce depending on the burner set up. I bought a couple of CO detectors.
First one was a straight alarm that would go off at about 75ppm. I then used a detector that gave a read out as well as an alarm at around 300PPM from memory. Be very aware of head aches using a propane forge as these are signs of CO poisoning which can take days to reduce. So going outside for ten minutes for a smoke to feel better than going back in could be very unhealthy.
I tried different extractors to remove the heat and fumes. An old kitchen extractor worked ok as did a lab fume extractor. Both would cut out after a time due to heat cut off switches in the motors.
In the end I basically would open the garage doors and have a fan blowing at the end of the room, blowing out the door.
The forge I mainly used was air blown and used for making Damascus so did get quite hot.
Andrew
That's interesting information about levels of CO.
The workplace exposure limit for CO is 20ppm over a full 8 hr working day or 100 ppm for a 15 min short term period. Don't need to tell you what the effects of exposure are. By the time you know something is wrong there is often nothing you can do about it
Play carefully folks !!
[even if I knew what I was doing
