emyrhunnam
New Member
- Bridgend, Wales
I've recently been restoring an old Polaris D-Bat 400 quad bike that uses a yanmar l100ae. After fitting the necessary parts I was eager to start it up without an air filter, bad idea. A piece of square cloth about 5cm got sucked up and I immediately turned off the engine. Since this I have had no compession at all. I've removed the head and the valves and piston rings seem to be working fine. There are no obvious cracks on the engine and I fitted a new head gasket whilst it was off. I'm only 17 so I really have that much knowlage at all so any help to troubleshoot this will be much appreciated.
and is stopping the inlet valve opening you need to take the rocker cover off and crank it over and watch the valve operate BEFORE spending on another H/gasket
