I have flushed the cooler and it seems fine.Handle pulls off in the direction of the cable.
Coolant hoses usually have little ear clamps on.
Cut those off and pull off the hoses then try blowing again.
Then you can work out if the blockage is in one of the hoses or the head.
If it's in a hose try blowing or connecting it to the cooler while whipping it.
If the head try poking a bit of tig rod down there.
Hoses /heads can be replaced individually if it's that bad.
Either way, I'd flush the cooler and change the fluid unless you know another reason for a blockage.
Yes Rectus 21. Are those standard on new torches?If you remove the outer crimp carefully you can reuse the inner part and secure it with a ear clip.
Cooler end will probably be a Rectus 21, Photos & measurements would identify.
Tricky to do alone but if you hold the torch head and blow air into both hoses individually you can sometimes feel where the blockage is and save removing stuff unnecessarily.
If the torch has been removed from the cooler or the fluid was dirty probably a foreign body stuck in a hose and might blow out from the torch end.
If it's not been removed but sat for a while probably crud build up in the head.
If you do manage to poke/pull some crud out of the torch head keep hold of it then you can try and find a chemical to dissolve it
Jusy remember hoses are more expensive than heads if you need to start cutting things...
No, there is not really any standard.Yes Rectus 21. Are those standard on new torches?
All sorted thanks. It was a while ago now - but as a newbie you are forgiven - welcome to the forumhave you tried reversing the flow ,put hose on to gas bottle put 25 psi in if not clear reverse flow try that
