norlander
- Europe, mocycling paradise
Well, Lucky you! Mine was a boys only school![]()
OK-cancel that GYS/Kemppi comparison and GYS factory visit we were thinking of doing
Bit sensitive are we??OK-cancel that GYS/Kemppi comparison and GYS factory visit we were thinking of doing![]()
I have been a bit busy over the last few months. The idea still has merit. (The factory visit..)Bit sensitive are we??I have been a bit busy over the last few months. The idea still has merit. (The factory visit..)
KF
What? 10- 20seconds of welding? how do you do that by mistake? I mean there is no way you could see the pool right enough! I must of flashed myself thousands of times just quickly and have never suffered as a result - just shut your eyes instantly!
I was putting a couple of tacks on four bolt heads, I think I may have welded two with the welding mask, then removed the mask to swap over the earth and reposition the next bolts then picked up the wrong mask so maybe only a few seconds. I have very slightly gritty eyes and a few persistent spots in front but no real pain. The headache I had before the welding from a party last night
Dumbass think to do, I shall be making sure I put the grinding mask well away from the job in future and try not to pack too much into the couple of hours I get a week tinkering so I'm rushing.
glass blocks uv light, that's why people don't get a sun tan when working in glass housesI've done that lots of tines. Never had arc eye. The auto darkening lids are designed to block most of the UV light even when in grinding mode.
I was wearing contact lenses and my face was 2 or 3 ft from the arc. Its only 1mm steel i was welding.
This warms me cockles. I did think/hope that may be the case. Theyre not exactly welding goggles but at least there was a bit of plastic between the arc and my eyeballs. I was looking directly at the weld so most of my exposed eyeball was behind the lens, only a bit of the white round the edges.The contact lenses probably absorbed some UV so I wouldn't expect you to get laid low with Arc eye.
When being chassed by a police helicopter - safest palce to hide is a graden greenhouse for the same reason!
You'll find out about 2:30 am......Gravel in the eyes is the symptom.This warms me cockles. I did think/hope that may be the case. Theyre not exactly welding goggles but at least there was a bit of plastic between the arc and my eyeballs. I was looking directly at the weld so most of my exposed eyeball was behind the lens, only a bit of the white round the edges.
Im starting to think it might all be fine. It was nowhere near as bright as looking at the sun, which im known to do from time to time, for a laugh. Ive just never had it before and I was anxious about getting van done in time as it was. Some people report agony after a 1 second flash, some people say they regularly look at welds with no major effects. Im guessing welding sheet is much better than if i was welding railway track?
What he said ^^^You'll find out about 2:30 am......Gravel in the eyes is the symptom.
as said after 4hours you will know if u have feels like sand in your eyes and watering only lasts a day though No accounting for taste, really.It was nowhere near as bright as looking at the sun, which im known to do from time to time, for a laugh.
Does glass block IR as well?, that's what the thermal cameras detect.When being chassed by a police helicopter - safest palce to hide is a graden greenhouse for the same reason!
